Technical  Dash wiring for 124
Keith Whitler
Evansville, IN, USA.
I have 1976 124 convertable. The front right low beam, instrument lights, cigarette lighter and left front side marker light do not work. I have checked all te fuses and they are okay. What next, relays? Grounds? When the car is running and everything is turned on, I have tested the fuse panel and two fuses are not getting current (on either side of the fuse) What demon do Ihave and how do I fix it?
Also, how much trouble is replacing the top?
Keith
Clean your grounding pods especially the one for the right front. I'll dig you up some information on the top shortly.
John R. Rushton
79 Spider 2000 http://pub79.ezboard.com/bfiatcenter
I don't know about the wiring but I can answer about your TOP...
You can chance the TOP it will save you lots of money, if you have the time to do it... It took me about 6 hours to do it by my self. The only thing you really need to worry about is inserting the hard plastic into the tounge of the car, once you rip the top you'll see what I mean...
Good LUCK!
