Cupar code read`s
Cupar code read`s
wigton - cumbria
Right as people know i have bought FES ( fiat ecu scan) and i have all the availble leads which means i can can support ALL these cars ..
http://www.fiatecuscan.net/SupportedVehiclesList.aspx
for £5- i will Plug your car in to the computer , Read all the errors .. and delete any stored errors ..
For £10 - I will Turn of service lights
for £10 i will use reprogram , re proxy aligne (sp)
ive done a few cars and cleared them all ..
i have done Clock34`s Fiat stilo , with this it had Asr , tsc errors , Due to a error in the steering wheel alignement , ( it was reading -120% out , So had to Relearn that .., I also Cleared the service light and cleared all the errors .,
I can Also Do the older Fiats as in the 3 pin Obd as in the cinquecentos and the punto mk 1`s , but i can try outher`s
So if you would like any work done Please Leave your NAME. and your Car, and age ...
:crowngrin:
discounts availibe to Fiat scotland members
I'm sure it obvious to most but these prices are massively lower than anyone would pay in a dealer or even an interdependent (Indies who probably wouldn't have half the diagnostic capability you get with FES).
Also if you have all the different cables It might be worth a wee sandwichboard of some sort. Advertising for the Alfa lot, They are the only brand in the world with worse electronics than Fiats after all. :D
alfa ecu/wiring looms are all pretty identical to fiats. hence fiat ecu scan supporting most alfas.
i can confirm a dealer wanted £30 to read my errors and £10 ro re-learn every sensor after that. so for asr, esp, abs, steering they wanted £70.... james did it all and it works perfect for less than £10.
cant complain..... also alot of errors may be hidden. aircon errors ect so worth a scan just to check the health of your car electrics and keep an eye on underlying errors....
i understand james has spent €50 on the software alone and more than that on the cables so lets try and get some of that back to him aye :)
I remember when there was an engine warning light, local dealer wanted £65 just to diagnose it so your pricing's rather decent :)
Nowt wrong on the electrical front with mine at the moment (fingers crossed), so won't be partaking but still, good opportunity for those who need it :)
I know when I had the Sei & the engine management light stayed on pretty much all the time.
Went to Arnold Clark, they wanted £40 for a diag, went to Audiowise in EK & got a basic diag done for £5.
I'll give you £5 James, see how healthy Dubster is, he should be very healthy, never misses a beat.
He just doesn't like being left for 2 or more days, he throws an Italian strop.
good good andi, im sure james will be happy for any custom :)...
i was suprised just how many errors dont bring up any dash lights! i had loads stored in abs, steerig ect and no warnings on dash haha
You can give mine a check if you want mate. As far as I know only the bulb light is on, and it's not exactly distracting. If you stick it in and see what it reads i'll get what ever is on it sorted; incase anything is hidden. :)
NOKKA / Ryan
MK2 Punto 16v Sporting, 1.2
2003.
NOKKA / Ryan
2003.
Thanks you
