Technical Croma CHT rear tail light gaskets
icom102
Hi
I have a leak in the boot on my Croma CHT it seems to be coming in round the light I need a new gasket I don't suppose anyone would have any or know where to try ?
Good luck with finding one of those. ;)
Make one perhaps?
High density foam.
Thick polythene.
Thin leather.
On a different subject; Is your CHT a Mk1 with rectangular headlamps? Or a Mk2 with trapezium shape headlamps?
If about 4-5mm of foam will seal it, go to B&Q and find a roll of adhesive backed draught excluder. Make sure lamp body is clean and dry so the foam will stick well, and keep any joins at the bottom.
Alternatively, get a tube of gasket sealant, (like around your bath, but specifically automotive as it has less acid in it). Cut the nozzle to make a large diameter bead, and lay oout a bead around the lamp. Allow it to set and you've made a gasket.
Was there not a facelift CHT as well?
