Technical crankshaft pulley jtd fitment
panda54
I need to replace the crankshaft pulley on my 04 1.9 jtd.
Are the pulleys all the same for this engine?
The one I have listed on eurocarparts says it is not the correct fitment.http://www.eurocarparts.com/search/347510021/p/home.
The same one on carparts4less(same company)does not come up as incorrect.
If there is a difference what do I need to look for?
@panda54
That one will fit.
If you put your car into the finder it comes up with the sme part as correct.
http://www.eurocarparts.com/ecp/c/F...a83d87876871f90723f8c410386d8082805dde&000091
From when I changed the damper on my 1.9 110 JTD Marea a few years ago, there are two types, one with a thin center flange and one with a thick flange. They will both fit, but use different length bolts. You should fit new bolts anyway, so check that he pulley comes with them or order at the same time. I changed from thin to thick flange on the Marea.
There are two reasons for changing the bolts, the old ones may have stretched on installation and the bolt locking is a chemical epoxy patch (looks like blue paint) which is not re-usable.
Robert G8RPI
Thanks for the info G8RPI.
It says the pulley comes with screws so that looks good.
