Hi, I have a '99 polish maluch where the stationary rpm seems a bit high. Checked for air leaks and fixed one. I've already set the idle screw to almost nothing, disengaged the choke, closed the mixture screw more and more and that helped somewhat.
So maybe the timing is off somehow? Now when I use a stroboscope light to see if we have anything close to the 10o BTDC , I'm getting a reading closer to 30 or 40, way out of scale.
Yet, I don't have a distributor that I can easily change; I have a crankshaft sensor which is bolted and doesn't seem very adjustable. Does anyone know whether this is normal or know how to adjust this? I'm hoping that changing it will ease down the engine
Hope someone can help
Regards Jeroen
Regards Jeroen
