J juggalugs New member Joined Dec 25, 2008 Messages 17 Points 4 Jan 11, 2009 #1 couple of weeks ago my car would not rev and died everytime i put my foot on the accelerator well now it wont even start has anybody got any idea's???????????
M mattkh New member Joined Dec 18, 2008 Messages 45 Points 10 Jan 11, 2009 #2 Hi Put some petrol in it, at least half a tank.
OP OP J juggalugs New member Joined Dec 25, 2008 Messages 17 Points 4 Jan 11, 2009 #3 its got over half a tank in it and there is petrol getting to the fuel rail.. the plugs are firing anymore suggestions very much welcomed. thanks
M mattkh New member Joined Dec 18, 2008 Messages 45 Points 10 Jan 11, 2009 #4 juggalugs said: anymore suggestions very much welcomed. thanks Click to expand... Hi Could be wet plugs. Take them out and dry them.
N NigelO Member Joined Sep 1, 2007 Messages 159 Points 108 Jan 14, 2009 #5 is it a 20vt? - if so, it sounds like the phase sensor - tells the ECU what position the crank is at so it can fire the plugs you need to get a code reader plugged into the car to tell you for certain what the problem is
T Top Shotta Member Parked in the garage Joined Jun 15, 2006 Messages 205 Points 106 Location Derby Jan 15, 2009 #6 Will it even Turn over, or is it just dead???
G gassy1974 Patron member Parked in the garage Joined Nov 22, 2008 Messages 31 Points 13 Jan 17, 2009 #7 if its the phase sensor it will bring injector light on
A arno New member Joined Jul 2, 2007 Messages 116 Points 19 Location Schuinesloot Jan 19, 2009 #8 Did you find the problem yet ? Same problem on the Tipo side.......
