Technical Coupe disc's
the mk1 kid
Hi all,
I own an uno turbo, not a coupe (bear with me please), but am in the process of fitting Wilwoods with coupe 16v NA disc - trouble is the offset, or height of the disc is incorrect for the bracket (known apparently ro be right).
Q, my discs are 284mm dia, and if they're right (i have only just twigged ui could have got sent the wrong ones!!!!) they should be 39.4mm high.
If mine are indeed as described above, does anyone know of a coupe (my research has all lead to coupe discs) with a shallower disc?
Am i right in thinking the 16v turbo has a deeper disc, circa 40.5mm?
Thread on turbo collective, with pictures:
http://www.turbocollective.net/phpBB3/viewtopic.php?f=10&t=1940
Thanks in advance!
Tom
Non turbo rotors are the same as Tipo 16V. Turbo rotors are slightly different as the hubs are slightly different. Its only a millimetre or 2 at most but I cant remember which way.
Hi Dave,
I might have got mixed up when trying to remember the turbo sizes - either way, the 16v NA discs were too high, and i knew the turbo's were bigger and going to make the problem worse.
I measured up (well i didn't per say - i used washers as spacers until i got the right fitment) and got the brackets skimmed 2mm, and now they fit perfectly! :)
Thanks your your reply
Tom
