What the hells going on under the bonnet!?!
Did you not know about that when you bought it?
I'd be annoyed. Thatll be a pain to sort
No -- I didn't know that when I bought it -- the whole chassis and underside of the bonnet is that colour too :bang:
I was a bit "miffed" ! But I got the car to restore and, taken a bit at a time I will clean the bay up. With the front end off it won't seem as bad ! (I keep telling myself that !
But, as you say, not too bad in all. Might have to source new doors -- skins are OK but the frame has rusted badly. Door quarter lights need replacing and the "glass" is perspex. Is that standard??
I am told that spitfire softop hoods will fit --- any ideas on that one ?? That'd make it water tight(ish) until I get the hard top fixed.
Oh -- the exhaust is 90% flexi-pipe and I think the engine is Uno![]()
The blue is a disaster. I dont know what you want to end up with at the end (fast, special looking, swimming pool with the blue look)? I think if you want something a bit nippy, get hold of a fiat uno turbo with a working engine and dump that in there.
I THINK? the 138 series is a FIRE engine and the design is similar in unos, x1/9s and a few other things.
So you dont know if it starts yet either? Is the alternator belt blue (ie has the paint bomb gone off since it was last run?
Doesn't look like a fire engine, athough its very hard to tell!
If you want turbo power you will probably be better off fitting a FIRE engine from a punto/cing 1108/1242 and turboing that. or going for a 16v conversion.
I expect it will look really good cosmetically after a good clean and polish
Firecats were made from 95 onwards, your is a later one. The registered in 87' refers to the donor car, so if that was the donors engine then its an 87.
I saw a working uno turbo car for £400 recently- best to get a whole car and take the loom, the engine, all the infinite sensors and parts which come with it rather than turboing a non turbo i would think.
