Technical Correct Oil for Multiair 105 NA
oldmanofthesea
United Kingdom.
For those of us who also own, or used to own, VAG group PD diesel engined cars I've noticed that the VW own brand Quantum Platinum oil I used for my Fabia vRS (had it 7 years, still fondly remembered) matches exactly the Fiat 9.55535-S2 specification needed for Multiair petrol engines.
Its SAE 5W-40 ACEA C3, synthetic base lubricant with low ash properties. The Pumpe Duse injectors on the VAG diesels were sensitive to lubricant type and VERY expensive to replace so I guess similar demands to the Multiair hydraulics.
Can safely use up what I have left, instead of giving it away to a worthy recipient.
TPS outlets and other VW specialists sell Quantum oils, top quality lube at prices very competitive to main brands usually.
  • Quantum Platinum SAE 5W-40 (Fiat 9.55535-S2).doc
Seems good for MultiAir engines.
Fiat normally sell Selenia, but top range of price :(
If you have the good viscosity (5w40), the good grade (ACEA C3) and even the Fiat number (Fiat 9.55535-S2) you can't be wrong !
