Technical  Coolant temperature- Guys with scan tools pls help
aurick86
Established member
Bucharest
Could you guys please tell me what temperature the coolant temperature sensor should be reading after the engine warms up?
My spark plugs show that the engine is running a bit rich, and on a long trip i had MES showing the coolant temperature.. it was only 75-76 degrees Celsius.
That to me seems a little low.
I can find thermostats for the Bravo that open at 80 or 88 degrees C.
The temp would not rise or fall more than a 2 degrees and the dash temp gauge usually stays at the correct position ( the middle ).
The engine does feel like it's taking a little longer to warm up.. but not to much .. so maybe the thermostat is not 100% opened.. but it surely is not closing all the way.
Hi I am Driving a Bravo 1.4 T-Jet 2008 Manual version in Singapore. My coolant temp is generally around 76-82. Stays within the 80 range when idling or at traffic lights but generally stays around 76-78 while travelling on expressways.
Your temps are fine.
T-Jet engine use 80C thermostat.
88C thermostats are used on 1.4 N/A and diesel engines.
Hi guys!
I also have a Bravo T-Jet. I've noticed that coolant temperatures drop to around 69/70 degrees celsius when I go on a long downhill without pressing the gas pedal and the air temperature has been around 10. Is this normal or is this a fault on the thermostat?
