There's not much on this Forum that discusses issues with the control box and maybe that's because:
1. They are very reliable.
2. Many people have changed to an alternator.
3. They are old technology and seem quite daunting.
As mine is allowing 17+ volts from the dynamo at the moment, I had to do something. I have ordered a shiny new electronic one, which is less than £20
so I have nothing to lose by messing with the old one.
I have read that these things do actually require maintenance whereas I previously thought they were "plug and play", "fit and forget".
This one didn't even come off the car during the restoration and must have sat there untouched for 47 years; so pretty reliable.
MAL_7487 by Peter Thompson, on Flickr
The securing and terminal screws came out easily and under the cover it looks like new.
MAL_7483 by Peter Thompson, on Flickr
I have cleaned all the points contacting surfaces using very fine abrasive paper.
It seems that in order to increase or decrease the maximum voltage output of the dynamo I need to bend the metal support on the left hand regulator mechanism such that it increases or decreases the tension on the leaf-spring bearing on the moving contact.
MAL_7482 by Peter Thompson, on Flickr
It seems simultaneously, a very crude but very clever method which I will try once I have checked if simply cleaning the points has helped.
MAL_7487 by Peter Thompson, on FlickrThe securing and terminal screws came out easily and under the cover it looks like new.
MAL_7483 by Peter Thompson, on FlickrI have cleaned all the points contacting surfaces using very fine abrasive paper.
MAL_7482 by Peter Thompson, on FlickrIt seems simultaneously, a very crude but very clever method which I will try once I have checked if simply cleaning the points has helped.
