- Joined
- Aug 25, 2011
- Messages
- 178
- Points
- 85
Hi guys, just rang the garage, and for my cilinderhead to be skimmed, the cam needs to come off, so i figured that is the perfect excuse to fit an 866 cam right away. I do have a few questions though:
1) do i use the p75 cam sprocket, and if so, will the timing mark on the sprocket match up with the mark on the head to give me the correct timing? if not, how do i set the timing up correctly using the cinq cam sprocket?
2) i assume i'll need to replace all the bearings right?
3) anyone know the valve clearances for the p75 cam?
I looked around a fair bit, but i havent found any solid answers yet, so some help would be very much appreciated
