My fiat punto grande 2006 will not start first thing on a morning. When I turn it on the engine starts briefly then cuts out... It takes around about 50 turns of the key to get it working and you need to put a few revs on to stop it cutting out for first few seconds... A warning message comes up on the dash saying warning fluid temperature at max.. The fan also comes on even though car is cold???? But once it it is running it runs fine all day and starts fine once switched off as long as you don't leave it off too long... The engine management light came on which apparently said it was a cold start sensor, we had this changed and it achieved nothing same problem. We also had a new battery this also solved nothing. The ECU has been tested this is fine no problem there.. Mechanic not sure what it is..any ideas??? read somewhere something about MAP sensor any substance to this?? need desperate help!!!!
Freda
Freda
