S
stuart
I've been checking the resistance measurement on the ignition coil thingy on my 1.6. Haynes gives readings of 0.6 ohm primary and about 9000 ohms secondary. I get a (good) reading on the low tension side for both halves of the coil but the high voltage side reads open circuit on all four terminals. I'm measuring it with a decent digital meter. Car is an old '96 with 90k.
Any experience of these coils failing?
I'm checking over the ignition and injection sensors because the car runs rough at low revs and can still be a bit tricky to start when cold (fine at high revs). It's the only problem I found so far.
If the coil is shot, where is the best place to get a new one - looks expensive
Stuart
Stuart
