Technical Coded injectors?
Greasytrucker
Established member
Leicestershire
Hi, can anybody tell me if the injectors on a 2007 1.9 Multijet Sedici need coding if replaced or is it just a case of getting one with correct part number? Thinking my starting issue may be due to a leaking injector and thus fuel running back when left which is causing the poor starting. Also has a bit of a misfire at low revs. Plan is to buy a used one and try it in all 4 positions to see if starting improves. Could always put a full set in if need be if it solves it
1,9 jtd 8 v 120 there is an injector code. Without it, it will not work properly, it tells how much fuel the injector injects in a split time. It would be nice if they could give it where you buy it from.
