Technical code light on cinquecento
ashley_1101
I need some help!!!
there is a key code light on my dash board, i have had tests done but no one can fix it!
i had my key tested and the codes are still on it, so i gather it must be the readers in the car.
i read a thread about checking the earthing wires, but i dont know where they are!
please help i miss my car!!!!
thanks.
My key code light sometimes flashes and then turns off again. Normally when you start it and put the key in the ignition.
Check +13v on ecu pin 35 with ignition on
check immo connecto pins 3 & 8 with ignition on for +13v
check key antenna for good connections into immo
check antenna ristance approx 30 ohms
if all ok send off immo for testing.
im really sorry but i dont have a clue about cars, where will i find all these things `reddy4bed`?
the code light stays on all the time.
the car isnt doing anything, i try to start it doesnt tick over.
i appreciate all the advise.
thanks
i think so when i turn the key it makes the normal noise a car does but doesnt start.
Dont think this can be sorted out by "push this button type" of answer. You need to take it to an auto electrician and go from there.
