I was a bit too eager pulling the loom apart forgot to trace the dial side wires, I traced the ones from the code box and ecu and just cut the rest.
I've got main power/ thick white 20A switches to red on engine harness, switched power/ thick orange to 7.5A fuse changes to thinner red-black then back to orange/orange-white for ecu and code box but I wasn't sure about the dash warning lights, it's possible one of the other wires splices i cut from the switched live also went to dash lights.
I guess code and fault lights aren't vital to functionality anyway otherwise the car would die if a bulb blows right?
I did spot a little diode (1n4004) and pretty big 100 ohm resistor on the pcb in the clocks for the battery warning light though, A diode in series and a resistor in parallel.
I'm guessing that was how fiat stopped the battery light back feeding the ecu relay/ switched live circuit, a diode to prevent a back feed and a resistor in case the bulb ever blows so that the circuit doesn't fail preventing the alternator from working.
