Technical Clutch stuck in neutral
Damummy
Uk
My grande Punto was stuck in neutral and wouldn’t change gear
On taking out the clutch actuator I discovered a split in one of the rubber seals
Could this cause the pressure to drop and therefore unable to change gear?
I have attached a picture of the rubber seal and would be grateful for any help
Hi all
I’m new to this forum so I’m not sure if I have missed something or maybe a bit impatient???
I posted about my fiat grande Punto semiautomatic being stuck in neutral and that I found a split in one of the seals when I took the actuator out
Could this be the cause of the problem?
Any suggestions will be greatly appreciated
Many thanks
