Technical Clutch problems
Kevlar55
Oldbury
I have a Fiat 500 2017, 23k on clock, started having problems engaging gears after driving for around 30 mins, changed transmission fluid 6 weeks ago after similiar problem, seemed to correct issue until now, any ideas
Shift cables might need adjusting? after 30 mins engine bay might have warmed up enough to put just a little slack in the cables leading to engagement problems!
Is it all the gears or just 1st/2nd or 3rd/4th/5th?
However if you dont know what your doing get it checked PROFESIONALLY as fiddling in ignorance could well make things worse!
Thanks will get a professional to look at it 👍
