Clock settings
Clock settings
M
Milan
hi, I bought damaged Bravo TD75. It was electronically dead, but I have elect. and mech. keys and car was returned back to life in official FIAT servis. Now I have a little bit funny problem. I am not able to set radio clock. Digits are still flashing even when radio is off. Time goes, but it is wrong. There some buttons marked as h+,h-,m-,m+, but no reaction after pressing. Radio and tape work fine. What could be the problem ? Btw. I am car beginner, does exist something like manual to Bravo in electronical form ?
Setting the clock
i) You need to hold the button with the clock/timer picture on it.
Hold it in for 3-4 seconds, then the time will be on the display
with either M1 or M2.
ii)You can now use the h- h+ m- m+ buttons to set the time.
( I think these are buttons numbered 1-4)
Also - You can use the other 2 numbered buttons (5&6 I think) to
change from M1 to M2 - these are the modes
M1 - normal operation displays Radio/Cd info when turned on
M2 - time is Displayed even when the radio is off.
When you are finished, press the clock button to return to
normal radio mode.
You may be interested to know that while the Stereo is OFF,
if you press and hold the MUTE button it will toggle between
IGN ON and IGN OFF - which sets the radio to go off when
ignition is turnned off ( or not as you prefer)
Steve O.
Clock
On my fiat I couldn't set the clock because tha radio would not remember the time after ignition was turned off. The solution was found after switching the 2 power leads going into the radio....
A
287
andyb76
A
M
6
315
M
R
2
327
M
