dimos47ki7
as the title says, i have issues with the climate control display on my T-jet 150
it first started with a couple of lines not properly shwoing, and eventualy it reached a point where all the display is not working.
when i press the upper left corner of the screen, everything is displaying corectly again, so it seems like there is a bad connector there. it also fixes itself when the temperature is above 18-20 degrees which, to me, indicates a really marginal bad connector which might just need a little nudge to fix.
the problem is i dont know how to remove the climate control unit, and if i remove it, if i can have access to the panel without destroying the unit completely.
any advice?
any advice?
