- Joined
- Aug 19, 2007
- Messages
- 554
- Points
- 129
Any guides? Idle is off sometimes, causing occasional stalling.
I removed my idle control valve a while back but did not see anything to clean , i could not see how it works either . the problem i had was when stationery when i went to pull away nice and slow the revs would drop like a flat spot then she would either stall or i would catch it time and give it some throttle ,
I have not yet tried to clean the airflow meter , Mine is an earlier B , so it is the just above the air filter box , is it simple to remove and what do i use to clean . ie carb cleaner as i use on the throttle body or can i use compressed air to blow it out.
