frodovic
- Joined
- Jun 24, 2013
- Messages
- 81
- Points
- 15
Hello forum members:
I have a small Cinquecento Sporting with a problem.
When the car reaches the normal temperatura (when its cold it runs fine) and I do a stretch of road just barely pressing the gas pedal, when I try to give more gas to rev up the car from 2/2,5k RPM the car starts failing and doesnt rev up. If I lift the pedal completely and press it again it revs up smoothly and fine again.
This started after I changed my battery and I found out that the ECU may have reset. Someone on a forum said that there is a procedure to start the car after an ECU reset (it said it came in the Haynes manual but I dont find it there) but I cant seem to find it.
Also, after I halt the car, I hear from the side of the ECU a noise like a baloon desinflacting. Is that normal ? Could this be a problem with the MAP sensor ?
Thanks in advance for your help.
