Tuning Cinquecento exhaust on seicento?
minimad
Could anyone tell me if a cinquecento sporting exhaust would fit a seicento sporting? i know cinq is a 2 peice but the shape seems similar on diagrams at least.
The final hanger under the bumper is slightly different. I've fitted a sei to a cinq, but my mate had to cut off and re-weld the final hanger.
did this last week, swapped cinq sporting onto a sei abarth. you have to give the front section a 'tweek' to clear the petrol tank as it makes it way back, what i did was use the last but one hanger in its standard position which moves the tailpipe towards the centre of the car by about 300mm, and then weld an extension of about 150mm to the final back box hanger - not too bad a job, sits tight to the mesh section of a abarth/ sporting rear bumper but doesnt bang and gives pleanty of clearance for speed bumps etc:slayer:
Anyone done this the other way round?
Got my eye on a sei system going fairly cheap and need to know how much of a pita it'll be fitting before I part with the cash.
the cinq is defo different needs adjusting, i looked at it and sacked it off, rear hanger has to be re welded and the front of the section needs moving as it does strike on the petrol tank. for a sei, so on a cinq the bends would be too big and would needf adjusting in the same places just the revers angle, so tighter bend around the tank and ect.
