B
BenB
Thanks mate, fitted the filter a minute ago
(Not a patch on yours Jayfish I know! That looks amazing!!) but on a budget (and with a proper cold feed pipe to follow), a very easy solution for the 1.6 that you famously can't get a kit for! Cheer Smee too for the fitting idea. I was thinking of spending a fortune on a real silicon pipe til you mentioned using the fiat pipe!
I got some pipe from a Tipo at a breakers (a bit smaller so it actually fits inside at both ends), I didn't have to sacrifice my original air feed pipe.
I know I know I know the original pipe is too restrictive, an ideally should be replaced, but like I said, on a budget, this sounds sweet!
