johnson550 Fiats since 1973 Parked in the garage Joined May 15, 2006 Messages 1,362 Points 336 Location North East Mar 16, 2008 #1 Hi had my timing belt changed a few weeks ago JTD 110 and the engine seems to be a bit noisier I was wondering if anyone new if the timing shows up on a diagnostics check or has it to looked at manually
jug blessed are the apostates Parked in the garage Joined Nov 28, 2005 Messages 27,935 Points 3,853 Location Durham Mar 19, 2008 #2 it will only show up on a diagnostic if it is out so much that misfiring is occuring, in which case you'll get misfire fault codes. a compression test is a quick and easy way to see if the timing is out, low compression on all cylinders means the timing is out.
OP OP johnson550 Fiats since 1973 Parked in the garage Joined May 15, 2006 Messages 1,362 Points 336 Location North East Mar 19, 2008 #3 Thanks Jug Ive just noticed youve moved have you gone there to give Tony some advice on his car
jug blessed are the apostates Parked in the garage Joined Nov 28, 2005 Messages 27,935 Points 3,853 Location Durham Mar 20, 2008 #4 i bought a house because they're cheap as chips in trimdon.
