You're wasting your time guesing and playing with the piston rings, a '96 car will be due for an engine overhaul by now if it is showing signs of wear. If you want to keep the car find a helpful, reasonable engine reconditioner and expect to get new bearing shells, rebore or rehone of cylinders, maybe new pistons, rings and a head refresh (valve guides, maybe valves). You should get back most of the performance of a new engine.
You can check the rings by doing a "wet" compression test, get readings for each cylinder as they are now, then squirt engine oil around the sides of each piston and repeat the test. if the oil makes the readings higher, it is sealing leaks due to wear of the block and rings.
