Technical Central locking problem
bubi
Hi everybody
I have some strange problem with central lock. On drivers side everything works fine but when I try to unlock the car from co-driver side it unlocks and then locks again. I dont think thats normal , can somebody help?
Car is Tipo 1.6 i.e. SX 95g.:confused:
Hi
I have had this happen a few times before, could be the locking motor itself (not known for lasting long at the best of times) take your keys out of the car! then disconnect the battery leave it 60 secs then try again. THis has resolved some of my issues before.
Let us know how you get on :)
Hi
I tried to disconnect the battery for 60 seconds as you said but there is no difference.
I guess its motor engine then, but i do not understand how it works when i lock the car from drivers side.:chin:
That is strange, it could be part of the motor has gone. I am trying to remember but i have had this happen and it was solved...
It used to do it to me on both sides and stopped me from actually locking the doors!
Can anyone else remember this problem??
Swap the Central Locking Motor from the broken door into the working door and vice versa.
See what happens.
If the problem swaps sides then its the motor... I think the motor should fit the door if not you'll have to do a temporary dangle motor from plug job and test it.
'Motor' actually has two parts - motor and switch.
What is happening here is that the switch is working (since when you unlock driver's side with key, the switch signals the rest of the system to unlock), but the motor probably isn't working, so that when unlocking from the passenger's side, the driver's motor is supposed to unlock, it doesn't, and then the switch is still in the 'lock' position on one side, so all the doors lock again.
Doing the swap side-to-side (as Transcedental suggests) will elminate broken wiring as a possible cause for the motor not to function.
Quite common is to hear the motor going, but for there to be no movement of the lock - a piece of sliding plastic breaks inside and can't be repaired easily.
The most economic solution is to attach a standard central lock motor (available individually or as part of a kit), which can replace the motor part of the standard latch assembly while you still leave the switch connected and working. The standard motor can be fastened to the door subframe, with a rod link to the existing lock pin. You only need the two-wire type, which you connect to the existing motor wires (I can't remember which colours off-hand, but PM me if you need me to look them up).
Standard new central-lock motor is worth about four pounds in your money :)
A replacement latch from another Tipo would be about twenty pounds over here, maybe more. As for the new parts price, I dread to think...
Thanks!
-Alex
