Cd changer - meaing of wiring terms?
F
Frank
Hi - I'm having a problem with Grundig CD changer - won't play/load/eject. Either dead unit or dodgy connection at radio end. Trying to diagnose with multimeter.
Does anyone know what the difference is between what the Bravo manual calls the "+12V power voltage" and the "+12V switch over voltage"??
I assume that if both of these (plus earth) are OK then the CD unit should eject or does it need some sort of communication to be present from radio? (Not sure because can normally eject without radio being on.)
Frank
