I still claim missing spark / shot coil (one of them).
The small vacuum lines black and brown, these should have nothing to do with the problem at hand. This two nipples I believe have some sort of thermo swich on the inside of the air box, and it controls the flap that lets in the hot air from the vicinity of the exhaust manifold into the inlet. The sole purpose of this whole contraption is to speed up engine warming up.
! But then on the other hand, if you have a problem with this, and your engine sucks in very hot air when warmed up, this could be it! The IAT sensor has range until 120 degrees or so, after that it would trigger an ECU fault, an ambient temperature of ~20 degrees is assumed, and this can screw up fuelling. Note that this does not mean that the IAT sensor is shot in any way.
This is easy to check, take off the air connector on the right hand side of the air box to get the air directly to the box bypassing the whole theromostatic contraption and see if that helps.
