Technical Can't get any gears - multipla Wreg Jtd
daved2208
19 JTD W reg
Just fitted a new clutch and new clutch master cylinder
after 9 days of an hour a night.
Now I can't get any gears when engine is running,
Will start in gear and drive the bite is 3quarters up but the pedle seems very easy to press but that might be me used to the clutch on its way out before the new one. Can anybody shine any light on my problem
Dave
It sounds very much like the clutch needs properly bleeding. there are 2 bleed nipples on the multipla (i think) there should be plenty of post on here to show you how to remedy, but sounds like not bled. Have you tried this: start engine, pump clutch pedal about seven times and on the last time keep it down and try selecting a gear. If it goes in then its def. a bleeding issue.
If the bite is 3/4 of the way up it does'nt sound like a hydraulic problem. Clutch plate round the wrong way as Zundapp said is a possibility, Outside possibility is the DMF as you did'nt mention changing it. If none of the above apply then it's possible it's a faulty pressure plate, partiularly if it's not a genuine (valeo or LUK) part.
