H
hlxfailure
Got bravo hlx failed mot on few points need little help to try fix them ;
1)Front windscreen & Headlamp washers dont work!
(I dont think its a pump fault as they are on seperate pumps(i have changed both anyway),it has water and it cant be the fuse either as you can hear them run!Is it blocked pipes if so how can they be sorted?
2)ABS light on
(came on when the brakes where excessively worn ,they have since been sorted,anyone know how to reset it without dealer/garage?If i could reset it, then came back on would that indicate faulty sensor? and how could i find out which one?)
3)Hand brake excessive travel
(brakes are fine,any quick and easy way to adjust the handbrake?)
4)x2 leaky shocks
(I take it you cant repair these?,do you replace in pairs(ie front&back) because they are both on the same side?,is there much difference in price between standard and aftermarket and what am i looking at price wise?)
I'd be very happy if anyone could help with any of or even better all of these questions
***Edited to conform with Forum Sellng Rules***
2)ABS light on
4)x2 leaky shocks
