Technical bugger! broke the nob bit that the vaccum hose from the fuel regulator fits onto!
Derbyshire
as the title says really!
i've broke the bit that the vaccum hose from the fuel regulator pushes onto under the air box on my 1.0L!
i was replacing the old hose as it was slightly split, so pulled it off and it pulled/snapped the bit it pushes onto off with it!
ok, so the car still runs, but it over fuels like a mofo now!
any ideas on how to fix this? only had a quick look and it looks like u can unbolt this bit as its attached to a couple more push on nob bits (technical term).
i hope this is all making sence :D
Dunc
if your talking about the 999cc Uno, a pic would help as I don't know where the fuel reg is :eek:
or do you mean the throttle body end of the pipe that goes to the vacuum advance on the distributor? it will run ruff if it leaks there as too much air gets in ;)
Dunc, you FAIL! :p
