brembo calipers for a bravo
J
jenks
is anyone sellin any brembo calipers off a 20vt coupe , i want some for my bravo hgt,,
also does anyone know if they fit straight on or do you need different fitment for the hub
you'll need to have brackets made up.
pretty sure the 20vT hubs wouldnt fit the HGT driveshafts are the are different.
Ry
Yes, no ,yes
I do have some brembos for sale (re-furbed in fresh powder coat broom yellow). If memory serves me they will fit with 20VT hub if you have hgt (as you do), or you use a 16v hub using a made to measure bracket, or by cutting the caliper itself and welding it on. 20v hubs as standard on yours are not appropriate. The prob then is the brembos stick out so much your wheels are unlikey to clear them, so you have to use 20VT alloys or keep whatever alloys you already have and fit spacers, if this is even feasible as a too large an offset will limit your turning, turn your bearings to butter and no doubt rub your arches.
I did manage to use my stock 20v hubs, but only cos I had split piece disks custom made to my own design and had brackets custom made too for the caliper, after working out I could fit my alloys on and get away with not using a spacer bigger than 15mm. And after all that trouble I never actually fitted the conversion other than for a quick test, cos I've moved on from bravos now (even though I've kept 'the mule' - affectionate term for my hgt ;)
@nico , cheers mate, are you sellin them if so how much
I
857
ian gardner
I
A
1
11K
Angelo
A
F
7K
F1-ANG
F
