Breaking & Squeaking
T
TT
Hey.
My car:-
Fiat Bravo 1.4SX 12Valve
86,000 Miles
N Plate.
My problem:-
(1)
When I start my car, sometimes, it wont star first time. Instead there is a noise which comes from the engine which sounds like its the starter motor. It doesnt try and struggle to start the car. Instead it sounds almost like its jammed. But if I turn the ignition off and start the car again then its ok and starts prefectly. Its been like this for over a month. Any ideas? Help?
(2)
Past two days running, when ive started my car on the morning and driven down my road. I come to a junction, and when I have applied the breaks ive had to force the pedal to the ground and the car has barely stopped. However, any breaking after that has worked perfectly and without fault.
Any ideas or help?
Thanks everyone!!
for the brakes, i recommend you check out the clutch cylinder (slave), and also the fluid level and when was it last changed?
Buzz
the poster formerly known as LightWarrior
The car hasnt been serviced in a long while ...
Perhaps its time I get my arse in gear and get it serviced ....
I
1
6K
stevew
S
G
736
Greg Crisp
G
427
dan brush
M
1
411
M
M
3
245
notorious131
N
