Bravo Turbo - Wiring issues
A
Anonymous
Hello,
I've been though the wiring diagrams three times now to try and figure out why the car wont fire, it is turning over but there is no spark, i swapped out the crank sensor for a spare to see if that helped but there was no change.
now, for those have done it you will know that going though all of the wiring diagrams to try and work out what goes where is no easy deal, it takes a long time! but still i dont seem to be getting any further.
i have noticed that on the Coupe 20v and 20vT there is an Ignition Switch Discharge Relay but this is not present on my car? do i need to get one and the wiring from a Coupe?
see diagram below
[/img]
if anyone could advise on this relay or maybe have a copy of the changes they made it would be much appreciated!
Thanks,
Scrap the above, i think its actually to do with the item just above it (number 12) the Timing Variator Relay which 'should' be connected to connector 149B.
i have connected one wire to the 149A block but the other two i'm confused what to do with :(
any ideas?
where do you live it needs to be checked by someone that knows how to do it
i am in Bristol, sadly i'm not aware of any Fiat specialists locally, nearest is Motomech in Birmingham :(
B
4
973
Dark Lurker
M
7K
M
I
6K
I
P
3
919
paull
P
A
1
11K
Angelo
A
