Hi I'm new on here. Just bought a 2001 1.2 16v Bravo. It's my project. I want to put a bigger engine in. I've been told that I can choose between the 2.0 turbo coupe engine and a 3.0 v6 Alfa engine. Any recommendations? Cheers.
Hey Bellie85, you're looking to post this in the Bravo/Brava section as you posted this in the Bravo Mk2 section. Hope you find the right advice over there on the Bravo Mk1 section
Starting with the 1.2 is more work for you, for a 20v turbo conversion you need a Bravo HGT as already has rear discs and the engine to ecu con.Hector is the same
The 3.2 V6 is also a straight swap but a lot of wiring is needed
