1997 1.4 Brava engine problems
Can anybody help please. I have just gone through the motions of correcting what was thought to be the consequences of contaminated fuel which was pumped out and replaced with new fuel from another source, after two session with two separate so called experts both with Snap-On code reader/analyzers both said that after fitting a universal lambda sensor it was not producing the correct readings and this was maybe down to wire crimping to attach the original socket. I purchased another NTK lambda sensor and also a crank sensor as advised by the expert and after fitting the engine does start better and ticks over more even but I still have the situation that after attaining working temp it will cut out on overrun and bring on the injection lamp as if the mixture is week or rich, it also from time to time will cut out but will restart ok now, also when the engine is warm if the throttle is snapped open it will sometimes back fire into the inlet manifold as though the ignition timing is out.
Any Ideas would be appreciated
S Dobbs
S Dobbs
