S
Stian
Hi, I've got a Marea Weekend 1.6. When braking at slow speed, the ABS goes bananas and turns on, the problem occurs on dry road. The ABS kicks in for a second or two, then the brakes is back to "normal".I thought it was the brake pads and discs that were worn out, but I have just replaced the discs, pads and brake fluid. (I have also replaced the rear brakes)
I can drive for a whole day without the problem occuring, but the next day the problem can occur many times. (The ABS is working fine when driving fast and I need to stop.....
The ABS light is operating normal. (When starting the ABS light is on, and then it is turned off).
Anybody have any suggestions ? Could it be the ABS sensors ? If so, how to find out which of the sensors that is faulty...
Cheers !
Stian
Cheers !
Stian
