Don't know if anyone has tried this but thought that I would post anyway.
Just put the Marea through it's MOT and it failed on a few bits and peices, mainly the brakes not performing.
The N/S rear brakes had a stuck slider on the caliper, which took an age to remove and it bent in the process so my brother, who has an alfa 155, had a spare one so we used that.
While I had it jacked up he had a look underneath at the brake compensator and said it was the same as his. He had allready modified his with a stiffer spring so we had a go with mine. We didn't change the spring but merely adjusted the bracket that the spring attached to ( see pics )
Thus putting more tension on the spring itself. It was a cow to stretch the spring into it's slots, but what a difference !!.
Braking from about 50-60 to a standstill and virtually no diving, the car seems to just squat under heavyish braking and generally fells more stable as well. Anybody tried this ??.
