Technical Brake Light Switch and No Reverse Lights
Coventry
mornin lads and lasses!
My brake light switch works the instant i touch the pedal i adjusted it a couple of weeks ago because it was doin the same thing and it was fine for a few days but now shes doin it again sometimes when i hit a dip in the road it knocks CC off... Is it shot or is it something ive done?
Also i have no reverse lights or reverse linked rear wiper... Gonna look at fuses today but wondered if there was a 'common' fault
Yes, common fault is that the reverse light switch has failed. It also feeds the rear wiper when reversing with front wipers on.
With regards to CC richy and it falling out over certain dips in the road, mine does the same on certain bad ones. I not 100% sure but have always assumed it were a safety feature incase youve come off the road and flown into a field etc :confused:
if it is ive not heard of it! mind you these things keep surprising me... i figured if the jolt was hard enough maybe the CC 'kill' half of the switch would activate before the brake light half... if that makes any sense
Do you know how to disable the rear wiper from getting the reverse signal?
at a guess it would be a parameter in FES but i dont ever recall seeing it
