Hi all I thought it would be a good time to sort our Croma's front and rear brakes AGAIN!. I should explain that over the past seven years our car has got through three sets of front discs and two rear and the wear has been ilogical and exaspirating!.So this time I decided that I would sort it out armed with knowlege gleaned from this forum and also from other forums particulary a very helpfull procedure from a Zafira brake bind suferer.So to start with I renewed the caliper seals front right and rear left as these brakes have tormented me repeatedly in the past.Sure enough both cylinders had dry and sticking pistons so no wonder they were binding!.I thought foolishy drama over war won ect but NO! we drove to Ashbourne to treat our Cocker to a good walk and when we arived I was greeted with the smell of red hot brake pad rear right this time so I googled the problem and the zafira person came to my aid and and provided a simple procedure of pumping the piston out pushing back and again to get some fluid moving around until the piston can be moved smoothly and easily without the use of weapons of mass destruction.However I needed to take the caliper down the shed and grip in the vice and set about it with sealeys tackle and red hydraulic grease behind the dust seal so I was able to push it in and out with one hand.Then back to the car bled ect two bolts tight worked the hand brake hand brake off and guess what binding still Grrrr slackend slider bolts and now loose. By turning the upper slider it was plainly bent so I unbent the thing and tightend up and at last all well.All thats left to do now is to change the Master cylinder!.
