S shotgun Established member Joined Sep 23, 2014 Messages 405 Points 155 Nov 15, 2016 #1 can you get the micro switch out of the boot lock or do you need a new lock the boot open is on the dash
Qube O Patron member Joined Jul 22, 2010 Messages 976 Points 309 Location Staffordshire Nov 16, 2016 #2 Had that problem a couple of years ago.....just blasted the assy' with WD40......solved it, been fine since. That said, could be I was lucky, perhaps your switch has failed....still, worth a try ! Cheers Qube O.
