Technical Boot latch wiring
Hello!
I've been searching around for a wiring diagram for the boot handle latch. My current situation as of now is in the picture below. I acquired the car in that condition and I would like to get it fixed.
The exposed ground as I believe is what I need to get sorted in order to get the handle latch working.
If someone has a diagram or knows of a way to get that fixed, please let me know!
https://ibb.co/hbZWHw
Thanks a lot!
I don't have a wiring diagram but that picture has helped me a bit! The boot switch on my daughters Stilo stopped working and I couldn't get the boot open except by using the OBD port with MultiECUscan to actuate the lock solenoid. So, at least I know the problem is in the switch rather than the lock. Problem is that I managed to get the connector off the switch in situ but now the number plate lights don't work as they are all powered by the same plug. (n)
The wiring diagrams are in the Stilo eLEARN manuals in the downloads section. Unfortunately my computer won't read the downloaded files. Hope you have better luck!
