Bonnet Catch stuck/snapped
Newcastle
the bonnet catch on my mk4 cabby seems to have snapped :(
went to do a oil check etc and i noticed the lead that hooks on to the realease mech was loose, i tried pulling on the wire and using plyers because it's too slack for the bonnet puller under the steering wheel to realease, this didn't work, it seems jammed.
is there any way i can realease it round the mech under the bonnet?
thanks a lot everyone!
sounds like the cable has come off at the bonnet catch, which explains why it is slack at the lever and pulling the cable has no effect.
unfortunately the mechanism is designed to make it difficult to open, for obvious safety reasons. i would remove the grill carefully so you can manually release the bonnet catch.
