Technical  big problem
markiz
hi
i write well but if you understand please help me
my problem ... i got an fiat tempra 1.6 ie a try to star yesterday but it don't star ..i had fuel the pump work i got Compression on fuel, but i notticed that the mini injector dont Spray continuuu ..once it start but about 5 seconds no more ...
what it\s the problem ?
please help me ...
if itis de injector can anyone help me with an injector ?
thx
it's possible that de intake air temperature sensor wich is on the cap injector not working ann cause that problem
markiz said:
hi
thx
Please check if you can get a spark from your plugs. If not you shoulfd check the TDC/revolution sensor (mounted next to the cranck shaft, right side of your engine).
Someone in a garage broke the base of my sensor and I had a very similar behaviour.
I hope this might help you.
Regards.
thx for your advice but it wasn;t the tDC sensor it was just fals air in my gas pump
