Depends on what your after I know 4x100 will fit if wobbly bolts are used but may require machining to fit the centre bores things like vw 4stud, mini wheels I think are 4x101 or 4x102 pcd again may fit with modification and wobble bolts, also look out for the et, you want as close to a et34 as you can, also consider sizes as going bigger than 14s as this will cause problems if lowering
