New alternator is in...and I have some good news, and some bad news.
The good news is that it half works...
thankfully, that half appears to be the half that charges the battery up.
The bad news is that the alternator light will not go out.
I am convinced that the battery is charging up however, as after a 45 minute run at around 80mph, the car was still going strong after using full beam, wipers and fan on full speed. After the run, I got the multimeter out and the battery was outputting 13.15V and I could physically hear the cells bubbling away.
So the light not going out makes me think that there is a grounding issue. I disconnected the thin wire from the Alternator, and the battery light didnt come on at all at any stages of ignition.
Anyone got any ideas what is going on and what I should try?
I need the alternator to get to work and back, but the alternator does have a 30 day warranty on it so I can take it back. I'm thinking that it is faulty and that it is causing the light not to go out.
Thanks in advance.
edit - Alternator DOES work - battery voltage with engine off = 12.7V, battery voltage with engine running = 14.6V
