Technical anyone changed an inner tie rod?
Think I've got play on the inner tie rod or drumstick!
Has anyone ever changed theirs? How did you do it? I just know its one of those easy jobs that will take all day!
Anyone changed an inner tie rod?
The usual arrangement of the Tie-Rod is this . . .
A one-piece rod and ball-joint assembly (the R/H end), there's a threaded section on the end which screws into the steering rack, the body of the ball joint has flats on it for turning with a spanner.
These are Multipla ones . . .
Multipla Tie-Rods
How easy/difficult it is obviously depends on the access to it.
Thanks doc..
That's what I wanted to know if the access is a problem..
I know that they sell dedicated tool to grip the larger diameter end as I don't think turning the actual rod will be any good as it will just spin in its joint!
Looks like um going to have to remove the gaiter and have a look.
No doubt it will be a pain
