- Joined
- Feb 24, 2009
- Messages
- 95
- Points
- 37
This is a wee bit long winded so sorry if I blab on.
Car in question - 1.9 M-jet, lowered and mapped. 56 plate.
Best to start at the beginning. Had the water pump, timing belt and auxilary belt changed when my timing belt had snapped due to a frozen water pump. In this process the engine was also rebuilt with new valves and the head was skimmed etc. Before my car decided to do this, there was no abnormal noises from anywhere.
After the rebuild the garage noted that the turbo was squealing very loudly and asked me if I wanted them to check it. So they checked the pipes and turbo to say that there was no holes and nothing obviously wrong the turbo. They did however phone the manufacture of the turbo to confirm that they arent the best and are not the most reliable. I have noticed this from several posts on the forum.
I thought it was a case of waiting till the turbo blew then I would fit another one. However, a friend was down at the house and heard the car. He has a vast knowledge of building and preping rally cars as well as racing them so I was willing to listen to him. He said that it couldnt be the turbo as you can hear it start to spool (or woosh
) before this high pitched squeal appears. He suggested it would be best to take of the plastic guard to have a closer look but was 99.9% convinced it was not my turbo making the noise. I have not been able to get it up on a ramp yet to check myself.
I popped into the Fiat garage over the Christmas period and the service manage was so un helpful and refused to even come out and here the car without charging me £69. I tried to explain it to him and he suggested it could be the tensioners for the auxiliary belt.
The noise is best described to be a high pitch squeal. You never hear the noise when the car idles at stationary. When starting from cold, the noise will persist from about 1100 rpm to nearly 4000 rpm. It happens every time you change up gear. If it is squeaking when going along the motorway of I put my foot on the clutch after two to three seconds the noise will disappear until I take my foot off.
I have not got a loss in power yet, just my patience. Its starting to really annoy me haha.
If anyone could shine any light on the matter it would be much appreciated.
